Steering wheel problem
spetros1
Hello.
I have a new yaris Active 2 weeks now.
I have a problem with the steering wheel. The cars aligmnent is perfect (checked ) but in order to go straight the steering wheel must be at 2 to 3 degrees left.
Also the  steering wheel revolving is not perfect . Is stops to about 45 degrees either way
The mechanic told me that all this are normal for yaris and the car has no problem ( I went to two different mechanics ).
Does anyone have similar problems ???
Thank you for your time
It sounds like the steering wheel wasn’t centred correctly when the alignment was done. Whilst driving in a straight line the steering wheel should be centred.
