Avensis T25 Rear Parking Sensor Problem
Filipe430
Hello,
minutes ago when I shift reverse, the parking sensors beep starts beeping continuous.
I searched on web and I can't find any scheem or vídeo showing how to reach sensors, or to the master modul.
Can somebody help me?
There is any video showing how to disassamble rear bumper?
Best regards
Hi Filipe, welcome to TOC :smile:
You don't say whether it is the original T25 or the mid-2006> facelift so I can't give you a direct link to the particular item but if you put in the relevant info into https://www.toyota-tech.eu/Aim/Aim.aspx?pubtype=AIM&menuitem=2 & look for parking aid system it should be able to help you with how it was likely installed.
