Two Questions : Mr2 92 Gt Turbo
BLOODUK
1.I know this may sound noobish i just want to know for sure ive only had the turbo for two weeks, When the turbo is at max boost, is it safe to keep going in the rev range ie red range third - fourth gear.
2. The audio system in the mk2 92 gt turbo are they active Speakers? , i tried to get a audio connector for my cdplayer but the toyota connection didnt fit , it has three prongs in the top instead of two , so ive ordered Smart Lead PC9-411 Item code: 957324-PC9411 Active System Adapter for TOYOTA (MR2 (With active speakers)) - ISO Leads/Harness is this the correct one? damn i really wanted it sorted its become a nightmare :ffs:
1. As with any car keeping it in the red can be dangerous, especially under boost. For the 89-92 turbos the max power is around 5500rpm anyway! the turbocharger becomes less efficient above that.
2. the speaker systems vary depending on specification, go here and check to see if the pinout is correct
1. thanks
2. hmmmmm see those two pins bottom left and right, mine has three that is the connection i got from Halfords, so i asked for other connection and it was £35! i hope its right cause this is really annoying me
Agreed.....BLOODUK are you not hitting the rev cut BEFORE you enter the red??
Cheers
KiwiMR2
PC9-406 TOYOTA AMP SYSTEM TO RCA HARNESS LEAD - This is what Halfords said they ordered for me , hope its the right one. Was ordered this morning so im hopeing its here tomorrow, wednesday being the latest.
On the early cars you should be geer changing at about 5.5k 6k rpm .. all the power is from 4k - 6k .. no point going to 7k as it's slower ;)
Thanks, only reason i wanted to know was i wanted to learn more about the car, as i was driving a honda it had the vtec kick in at 5000rpm and it was a rev happy thing. :P
I went from NA to Turbo .. it's a hard habit to get out of ..
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
