Engine light, vsc off, trc
Andyjk
Hi, the engine light and trc light are illuminated on my IQ3(61) and the vsc light is constantly flashing. I have had a service and the mechanic changed the lamber/oxygen sensor thinking it would remedy the fault, as that was the fault showing up on the computer. 20miles later and same problem has returned. We both at a loss. The car drives the same but the fuel consumption is terrible. Any help greatfully received.
I'd get it on a diagnostic check if not already done. Most garages have them or try Toyota.
Some Toyotas you have to have fuel cap on tight too or you'll get this problem. Seen it on you tube.
I also had this after a Toyota main dealer service and they told me it was due to the air filter housing not being fitted correctly.
  • 2 months later...
A few months on and the problem still exists :( I read above about the air filter box. Did this solve the issue please
Did this fix the problem please
