Axle Weights Yaris Hybrid
Mick F
What are the normal axle weights on a Yaris Hybrid?
I don't mean the max permissible weights, but the actual unladen axle weights (driver plus passenger no luggage).  I know the gross weight of 1565kg - 3450lbs is in our handbook , but not how each axle is normally loaded.
Thanks, Mick.
Isn't it 55%/45% front/rear loaded?
The max weights seem to have this distribution. She's definitely heavier on the front when empty.
Thanks.
That makes some sense.  It was an idle thought the other day, that they don't tell you the axle weights. I suppose the only way to tell positively, is to take the car to a weigh bridge.
Mick.
