I have a 1994 Carina E, and I wish to up rate the brakes, I intend on buying some larger discs and new calipers, but at the moment the car has rear drums, would anyone know if I would need to change the rear hub to the Carina E with rear discs, or does the rear drum hub inner fit ? Cheers.
Hmmm.... As with all these things.... Check Toyota rear disc models [Celica] to hopefully hit common bolt patterns/hub spec/handbrake cables :wink:
Keep us up to date.....
2sav
Cheers, will do.
Sorry Paul can't help you with this one, I have never done anything like that.
No worries, thank you anyway :D :D
