Reversing lights not working
amirmhmd
Hi all,
Would you be able to advise on what could be the issue?
I have Toyota Auris 2008 plate, Reversing lights does not turn on (Does this model has 1 reverse light or 2?) I have changed both lights right and left but still not working.
Would you please advise on what could be causing this?
Many thanks,
Don't know if it has 1 or 2 lights, but you could check the fuse related to the reverse light circuit. Also, there is usually a switch located within the gear shift mechanism, that operates when reverse is selected. The switch could be faulty, or the connector loose.
Thanks for your suggestions,
I have checked the fuse box that is located under the bonnet but how can i know which one is the reverse light as I don't have the circuit.
Is there a way to find the circuit?
User manual, page 448 and onwards.
Think it has one reversing light on the nearside.
If its one rev light on nearside then probably the rear fog lamp will be in the same place on offside - my Prius is that way.
My Auris has two rear fog lights and I am not sure if the reverse lights are one or two
