Avensis 2.0- 2006 fail code P0051
chris4
I'm having trouble with the wrong code P0051, Toyota avensis 2.0 2006 OBD FAIL Code is P0051 they want to say Bank 2 sensor 1, which side, if you're in front of the car, left or right, and what item number does it have, would have DENSO do you have any tips on where to buy online, I live in Sweden. Regards Christian
Look at Ents post which should help a lot -
Courtesy of Ents, the layout of the sensors - $T2eC16hHJG!E9nm3sB1YBQtlT1bWng~~60_35.J
Thanks.
Christian
  • 3 years later...
I have the same problem exept i have replace the sensor and the code still pops up saying there is a fault with ground still showing even after delete the code
