Toyota Corolla Verso Diesel 58 plate
cigarette lighter fuse blows when ever a load is put into it even the phone charger.
Is it the socket?
Is it the heater solenoid?
How can I get to it to check wiring or replace it ?
probably just a standard socket for accessories like phone Sat Nav as I don't smoke.
Toyota parts department were helpful  in telling me where the fuse box is .
On passenger side behind the  storage box.
 pull it open it  and squeeze the sides  at the bottom and it will drop out.
Any ideas
thanks Rob
Check there's nothing inside the hole.  There's a pin in the centre at the bottom which is poz, and the metal sleeve is neg.  If there's something touching between the two when you insert a device then it could be shorting out and would blow the fuse.
no nothing in the hole I am getting a local firm that specialises in car electrics to replace the socket. The replacement part from Europarts is only a tenner . and he doesn't charge the earth for fitting .
I suspect the Toyota version would be quite a bit more the unit has a tube on the side ( heating element  or capacitor with a separate  feed). I suspect that is the bit that is US
