Leaking Sunroof
celicatardis
Just bought a new celica, seems to have a leak? Water dripped through the roof material, driver side, near the sunroof. It was whilst it rained heavily.
I pulled back the sunroof cover and I could see a small amount of water dripping in the gap.
I tried to look for the drain holes but couldn't see them.
Any ideas? I'm stumped!
Moved to the Celica club.
Water getting past the sunroof seal isn't an issue as the seal is not 100% water tight. If you open the roof back fully and look in from above there is a frame/gutter all the way around the aperture this is designed to catch the water and guide it to the corners of the frame where drain pipes run down through the car and allow the water to drip out underneath, if you have water getting in on the RHF corner then the drain is most likely blocked. Try using a piece of thin cable/rod and pass it down the drain pipes then use a watering can gently pour water into the frame and make sure it drains away.
