ABS Warning Light
Davewm5
Hi.
I wonder if anyone can help me. I've got a Auris 2012 1.6 and this morning the ABS warning light came on.
I pulled over and looked in the manual and it doesn't go into any detail, it just says there's a problem with the
ABS. I set off and the light went out - then came back on after a few minutes. On arriving home I checked the
brake fluid level. I topped up but only a very small amount of fluid went in.
I've just been out again and the light is not on at all.
Anyone any ideas would be very much appreciated.
If it's off, then no issue there.
If it comes back, have someone hook up the diagnostic and check the code, and at least identify which wheel it is, the sensor might just be dirty on 1 wheel.
