Satnav mystery
Jonmartin
I was using the satnav yesterday. On the journey to my destination, it was working fine. But, on the return journey it changed from miles, mph etc. To kilometres, kph etc. I can’t find anyway to make it change manually. It’s back to imperial today. Anyone got any ideas what happened, and is it possible to switch between imperial units and metric units ?
Don’t know why the satnav decided to use metric units, but I do know now, how to change between imperial and metric units.
thanks for letting anyone else that may come across this problem how to fix it.
that's the thing about these forums. if you have a problem some may have had it before and posted the fix.
There is a software fix for this included with a Sat nav update you can either speak to your dealer or register on MyToyota and download via the "estore"
I downloaded and installed the update, but the problem persists. The car is due a service soon, so will mention it to the dealer.
It would help if you told us what satnav version you are using.
