Feature enable / change
Aidsy1
Hey guys,
Does anyone know if you can (without going to the dealer) change how many times the lane change indicators flash for? And also if you can enable the lights when you unlock the car?
Cheers guys
Does your profile need editing to include the Auris - currently showing an MR2.
Hi if it is the same as the Prius the answer is yes .
No aha, I have both 😊
Sorry, is that yes to going to the stealer?
So why not include both in your profile.
Hi the answer is yes when mine was changed I was not charged also I had the reversing beep changed to one beep with no charge . If the 12v Battery is changed then it reverts to the factory setting.
