Replacing 2007 1.6 Auris battery
furtula
I should be changing the Battery before winter, but in the manual i did not find the numbers for the Battery, but i presume should be 55-60ah.
Manual also says the radio presets, A and B odometer will be reset etc, but that should be, can anyone confirm it is so?
Note, i got smart entry and start system, but the replacement should not affect this.
That all sounds about right, at least on my 1.33 (2010). Radio loses its pre-sets and the trip meters are reset to zero. Clock will need setting and any MPG data will be lost.
