Screw in Brake Piston advice
Manelda
hi
I'm replacing rotor & pads on rear brakes.      2014 older style hybrid
The pistons are screw in kind, I've had a tentative look to see
I found that I can manage to turn them with nose pliers ( I'm awaiting a cube adapter),  but they don't seem to retract to a noticeable degree
any tips I  would be grateful for.
Do they turn clockwise or anticlockwise ?
Why, isn't it still under warranty?
Well, it just had service & they advise needing replaced cos of bad grooving on rotor.
So I assume they would have said it was warranty, rather than quote around £400
It had not occurred to me till you've mentioned  it though.
they quoted £400 for rear pads and rotors? bit steep
Even a Toyota dealer is cheaper than that when referring to their fixed prices (£235).
Pads and discs will be a wear and tear item.
14 hours ago, Manelda said:
….. any tips I  would be grateful for.
My tip is RTFM 😉.
Go here: Toyota tech site, register and get access to the workshop manual. It is PAYG and costs around £3 for an hour's access.
Worn/grooved discs would not be covered under warranty at that age
Ask for the Toyota fixed price (you shouldn't have to ask) TFP is £270 on that model
Is it £270 for a Yaris? £270 is quoted for Auris and £235 for Yaris on Toyota's website under maintenance and repairs .
what  TFP mean ?
When I was listening to the cost of parts I was half switched off as I wasn't going near their place the price was getting well over 400 .
Now that I remember it included wheel balance & engine flush so take that off say 450 & what was left was what they were asking for brakes.
Anyway I bought a full set for £80.
If I choose cheaper the full set is less than £30 :
Hi, the screw out action is to keep the hand brake adjustment. It's a bit fiddly, but use a 'G' clamp to keep the squeeze on and turn the piston with a pair of 'Swan (or Goose) neck' Pliers. Don't forget to release the hand brake first. Good luck.
TFP = Toyota Fixed Price
Mate those discs and pads will be made from butter and will last 5 minutes if you are lucky
Get something decent, if not genuine then something like Ferodo, at least you will stop when you put your foot on the brake
Kingo :thumbsup:
Kingo :thumbsup:
I bought Brembo ones , so I hope they are decent enough.
Yes, should be fine
The cube adapter just popped in the letterbox  , so I will make some plans
On 5/30/2018 at 11:21 PM, Manelda said:
Arnold Clark
they are total pirates id rather go another toyota dealer or a good independent for the brakes
Wheels are on now , used long nose locking pliers to insert into holes in piston, & push in( with force) while turning Clockwise.
The cube did not fit. There are a few combinations it , but just not for this Yaris - unfortunately .
Arnold Clark
Or as we cll them in the motor trade Arnold Shark.
