Good day.
I am trying to restore my old beloved EE101 and the braking system needs an overhaul.
Some of brake slider pins are stuck: one on each wheel.  And I mean seriously stuck - I've tried in every way I could think of to get them out. It's rust. The car has been idle on driveway for a few years.
So I am instead trying to source replacement brake brackets (the part that holds the slider pins).  I've searched japan-parts.eu and have yielded the following part numbers:
47721 (right side)
47722 (left side)
I have searched for these parts online and found few, yet expensive results.
My question is, is this a relatively generic part? Can I find a cheaper replacement by searching with a different search term - perhaps a model number for a more modern car?
My VIN begins with: jt154eea1001
I greatly appreciate your feedback!  Here are some pics of my project. Enjoy!
Have you removed the bracket from the hub ?   usually just two bolts, though a good dose of penny fluid overnight will help.
Once off then you could place it so the pins are vertical , then again use some penny fluid to trickle down  and leave overnight or soak in a bath of some fluid etc.
Using heat might also help, but be aware one of the pins may have a rubber end.
Cannot see it being a generic part or available from any aftermarket supplier, Mr.T only if they still have them, or a scrappers.
As long as the bore of the pin holes cleans up without any bad wear or scratches it should be ok..
For new pins try https://brakeparts.co.uk/
17 hours ago, oldcodger said:
Thanks a lot for the very good tips.  By penny fluid, do you mean WD-40?
WD40 will work, but have found things like Plus Gas Dismantling Fluid work even better.
Also patience, for such seized items , clean away any muck around the area and give a good spray but then repeat spray every few hours and leave overnight to really let it work in.
If you can find Plus Gas it is really good at loosening stuff fast :smile: I last found some in a Bike shop of all places.
Thank you all. I did what you said, placed it upright. Heated it over kitchen fire, and then used breaker bar to spin it and eventually free it. 😀
Plus Gas. It is the stuff!
