K&n Filter
mokhan
hi, i am new to the club and have some questions to ask
i am going to get a K&N induction kit for my starlet 1300 (1999) and i need to know how easy is it to fit on? and were would be the best location for it? - taking the filter box out placing it there! and what about the air pipe that comes from the front grille?
many thanks
Hiya and welcome to the club,
Induction kit's are easy to fit. in effect it is a straight swap for the air filter you have on the engine as stock..
If you hold the new K&N pipe over the top of where the existing box is you should see where the pipe and filter need to fit, shouldn't take that long to swap over...
As rhaines said it should be an easy job but just check the K&N has somewhere to fit the sensor back into that is in your air box.
I had an sr starlet which was a 1.3 i changed the filter to a blitz one and one of the reasons i chose it was that un-like the Ram air one i was offered it had the correct hole and seal for the sensor
Simon :blink:
don't know what your engine bay's like but make sure you're getting cold air to your filter otherwise it might not be any better than your stock item.
