Brake Pads
jives
are the pads on toyota celica gt-r import but uk spec diffrent or are they the same ?????????
the car is 1990 model PLEASE HELP :ffs:
i would think exactly the same , take an old 1 with you to your local motor shop and they will match it up . most parts uk and import are exactly the same.at the end of the day its the same motor . :thumbsup:
1985 upto 1994 = st162 - no pad difference
1990 upto 1994 = st185 and st182 - same pads also no import difference.
1994 onwards = st202 pads are different from the uk model to the jap import.
call here for a quote and info . http://www.brakesint.co.uk/enterflash.html
but they are half price at your local motor shop. got mine for £ 11 fronts rears were £ 15.
Edited by maleborn1967
welcome to my world mate?.
i still aint got my brakes done because of this problem and they are getting really bad..
roll on a fortnight, as im off and determind to fix them
I also have a GT-R :wub: and as far as I know the pads are the same as the English.
having carefully studied http://english.auto.vl.ru/catalog/toyota/celica/
only difference between a st 182 st185 and st183 is that the st183 had 4 ws , everything else is the same .and the engines have different power outputs .the real differences are with the gt4 and the later st202.
how did you get the specs from that information?
hey maleborn, i know tthat you know your stuff,
sio i went to that link, got all excited because i thought i could finally find my car,
but.........................
my chasis aint listed....
e-st183-blmzf
frame 0022599
can you help any further?
Pretty sure that your vin plate is marked up wrong as its too uncanny that all versions are listed and not yours.,Only 2 variants are listed GT-R 4WS equipped car -manual - E-ST183-BLMVF - and the GT-R 4WS equipped car automatic - E-ST183-BLPVF . Besides that brake pads from a st182 and st185 are the same as a st183.
if you look at the chart you will see the st183 got its name because of the 4 wheel steer , nothing more.
