Rav 4 hub?
Jayreina2014
Hi:)
firstly hi everyone and thanks for the add :)
not sure why I didn’t join this years ago but hey I’ve come to my senses :) lol
anyway our 2.0 Vvti rav 4(02) plate need a new o/s front hub... I just wondered if the avensis(or any other models) have the same hub ?
many thanks
jay :)
Hello Jay - welcome to Toyota Owners Club.
Moved to the Rav4 club.
The correct aftermarket hub is around £23. If your question regarding alternative fitments is because you want to source an used part - it’s probably not a particularly cost effective option.
Hi
thanks for your reply and advice :) I have two issues with my hub ... the Bering has gone and has a snapped stud, I was considering a used one as our scrappy has 109’s of Avensis but no rav 4’s 😂
i will ring around today and see if I can get a new one :)
thanks again
jay
You probably don’t need to replace the hub - you can knock out the broken stud and fit a new one when the hub is removed to change the bearing.
Evening Gjnorthall
thanks for that knowledge on the stud... I actually thought they were welded on lol but if they knock out that is so much better 🙂 ill ring Toyota parts dept 🙂
thanks again 🙂
jay
