Air Conditioning failed a few days after regassing - 2002 RAV4
eddiey1
Hi I have a petrol 2002 RAV 4. The air conditioning stopped cooling a couple of weeks ago so took it to my local independent. They regassed the system, added new PAG oil and did a UV Dye leak test and pressure test. Has worked fine for 4 days, then today, on what is a very warm day, the air con seems to have failed. When I switch on the air con button there is a slight rattling sound as the compressor kicks in but no other noises. Is this a common problem or could it be one of several things? If it needed it, are the air con compressors expensive to service or should I look to get a reconditioned one off eBay? Any help would be much appreciated...
The first thing to establish is whether it has, once again, lost the refrigerant.  As you have dye in the system, it should be possible to spot the site of a leak.
If the aircon was refilled only two weeks ago - return the car to whoever did the job.
Thanks - couldn't see anything myself
It's gone back there - hopefully not too drastic a repair required....
