Sat nav update
j66
Hi all tried searching but talpatalk is playing up a little.
I have 2017 Auris with software version 6.8.1WL
MAP ID 2016v2
Dose the vehicle qualify for any free map upgrades.
?? Not sure if it dose.
Cheers 🥂
Sent from my iPhone using Tapatalk
I believe it does. You’ll have to go to mytoyota and click on the update, to put it in your basket, as if you are buying it. Then when you go to check out you’ll see what the cost is.
Cheers I’ll try that in a bit.
