Overdrive Button
Doodah0784
I've just got a 2003 automatic Avensis Estate and cannot find an overdrive botton which I've had on all my previous automatics.  Can anyone tell me if there is one on this car and if so, where it is please? Thanks.
Progress. Older cars auto O/D used a lock up on the highest gear or had a 4th gear and class it as overdrive. The button basically was to lock out 4th gear or enable it. Electronics improved and the button was not needed. Plus manual mode came in. It helps economy to get into the highest gear possible.
I would not worry about that button. Make sure the auto fluid is topped up and good.
Great, thanks for your help.
