Anti.roll bar bolts
Jayreina2014
Hi
Had a bit of a job getting the bolts out of the front anti.roll bar brackets to change the bushes however finally did and thought I'd take the opportunity to rep!ace them. Would anyone know what size bolt and type i need please ?
I'd guess it is high tensile ,fine thread but u want un sure pitch and size ?
Many thanks
Jay
Don't know the size of the bolt in question but the vast majority of bolts on Toyotas are the common metric fine type. If you go for grade 10.9 bolts (10.9 stamped on the head) - you'll always be OK in terms of tensile strength. Just match up the shank size (M6, 8, 10 etc) and the bolt length of the old bolt. There are critical bolts on suspension components and engine internals which are non-standard (eg stretch bolts or bolts with non-standard shanks / head size. For your safety, if in any doubt - order the fastener from the Toyota parts list.
