Some help...
tmdmitza
Hi, after my car avensis 2007 2.2 dcat 177hp no more starting i start to travel in some service with the car on platform inclunding toyota dealer service but with no result all of service mechanichs they don't now why she not start....  the hight pressure pump it new , the diesel filter new.... and i have no error with techstream but i have some data and i want to ask if somthing wrong ...
AVENSIS    ADT    2ADFHV
7/9/2018 8:04:34 PM
[Engine and ECT Live] System
[Parameter]    [Value]    [Unit]
Alternate Duty Ratio    31    %
Vehicle Speed    0    km/h
Coolant Temp    26    C
Intake Air    32    C
MAP    96    kPa
MAF    0.42    gm/sec
Calculate Load     0.0    %
Engine Speed    0    rpm
Accel Position     0.00    %
Throttle Close Learning Val.     17.1    deg
Actual Throttle Position    0    %
Injection Volume     37.36    mm3/st
Inj. FB Vol. for Idle     8.00    mm3/st
Inj Vol Feedback Learning     0.0    mm3/st
Injection Feedback Val #1     0.0    mm3/st
Idle Signal Output Value    0
Injection Feedback Val #2     0.0    mm3/st
Injection Feedback Val #3     0.0    mm3/st
Injection Feedback Val #4     0.0    mm3/st
Pilot 1 Injection Period    0    us
Pilot 2 Injection Period    0    us
Main Injection Period    0    us
After Injection Period    0    us
Pilot 1 Injection Timing     0.0    deg
(CA)
Pilot 2 Injection Timing     0.0    deg
(CA)
Main Injection Timing     0.0    deg
(CA)
After Injection Timing     0.0    deg
(CA)
Injector Memory Error    No Error
Injection Pressure Correction     0.0    mm3/st
Target Common Rail Pressure    55000    kPa(abs)
Common Rail Pres Sens 2    0    kPa(abs)
Fuel Temperature    26    C
Target Pump SCV Current     1558.3    mA
AF Lambda B1S1     0.996
AF Sensor Learning Value     1.85    V
EGR Lift Sensor Volt %     77.7    %
EGR Close Learn Val.     4.00    V
EGR Close Lrn. Val.     4.00    V
Target Booster Pressure    113.88    kPa(abs)
VN Turbo Command    77    %
VN Turbo Max Angle     99.6    %
VN Turbo Type    Vacuum
VN Turbo Min Angle     9.7    %
Diff. Press. Sensor Corr.    0.0    kPa
Exhaust Fuel Addition FB     1.00
DPF No Activate    Activate
DPF PM Block    No Block
Catalyst Memory Error    No Error
DPNR Status Reju (S)    Standby
DPNR/DPF Status Reju(PM)    Standby
  • 2 years later...
