Trying to find out if my 2013 Verso 2.0 diesel  has a timing belt or chain and how often does it need replacing.  Can’t find any information anywhere
thanks Chris
Hi Chris, welcome to TOC 🙂
If it is a 1AD-FTV it will be a chain.
Hi thanks for getting back to me how will I know what engine type it has
 I am reasonably sure that it will be a 1AD-FTV. Not sure if they fitted the 2.0 BMW diesel to the Verso but that is chan-driven too.
Hi thanks again. I think from reading stuff online they did fit the bmw engine but not till 2014    Just as I said I couldn’t find a definitive on wether it had a chain or belt
I know that they fitted the 1,6 BMW diesel but not sure if they fitted the 2.0.
  • 1 year later...
As I understand a simple method to know about 95% of the time if the whole engine is metal then it has a timing chain but if one section is made of plastic it has a timing belt.  This section should be close to the alternator.
Given that the original post is nearly two years old he probably knows if it is a chain or a belt by now.
