Avensis 2012 windscreen washers
Outerspace
Hello. My first post on this site.
One of my washer jets is too low when it hits the windscreen. I googled the problem and soon found that this is a common fault on Toyotas. Also found that you cannot adjust the nozzle.
On the Auris owners page, someone said you can get 3 different angled nozzles -2, 0 and +2 degrees. The +2 degree part number was 8531 12350.
Would that be the same part number for my Avensis ?
Thanks for reading.
If you send Parts-King a personal message, detailing your car (reg.no as a minimum), he will be able to confirm whether there is a choice of jets and how much he can do them for.  He won't provide parts numbers though.
Thanks for reading.
Avensis -2 85381-20310
Avensis -1 85381-20220
Avensis 0 85381-20280
Avensis +1 85381-20290
Avensis +2 85381-20300
