Mk1 Drivers external door handle
VosperD
Not a major issue but this no longer returns flush with the door, if I push it home it springs out a bit. Doesn't look like it's been forced or anything and the door opens and closes ok. The return spring feels a bit weaker on this handle than on the other three doors.
Before I start taking it apart, is it something that can be repaired or is it a case of a new door handle?
Don
  Before you take it apart try some WD 40 (or similar).
