Front Seatbelt replacement
mark0
Lads is it a complicated job to replace front drivers seat belt on d4d avensis is there any air bags involved
No airbags, but there is probably a pretensioner system - which automatically tightens the seatbelt on impact to help hold the driver in place.
Thanks for reply there’s the bottom half black panel that GAins access to bottom seatbelt Bolts then there is the white grey panel the hides access to top bolts how to remove panel to gain access to top bolts
If your car is a t25 there are 2 clips at the bottom and one at the top that you can release with a screwdriver, at least according to the workshop manual. Ian
Sent from my D6603 using Tapatalk
