2011 1.33 Petrol Auris - Interior fuse box different to manual
Chorus11
Just bought a used Auris and found the cig lighter did not work. Checked with a voltage meter first, then tried to replace fuse. Looking in the user manual supplied it should be fuse 8 in the interior fuse box. But the fuse box is different to the one pictured in the manual, it contains more slots (32) and the position of fuses is clearly different. Anyone know of the layout of this fuse box?
Thansk
On my 2012 Auris the fuses box had 31 slots, but not all were used - only 26 were.
Mine actually has 31 as well, I've attached an image. None of the fuse values seem to correspond with the first 26 values in the manual! Any ideas where I can find the correct documentation?
I've also just cig lighter out and checked the terminals directly, but still no volts...
Is it not printed on the fusebox cover?
Finally fixed it. I realised that the numbers are wrong on the fusebox. Fuse 1 is bottom left, not bottom right! The fuse for the cig lighter is actually missing (it's the one above the 4 20Amp fuses), I've fitted a new one and it's working fine now.
" I realised that the numbers are wrong on the fusebox "
They look correct to me when referring to the picture in the manual. Looking at the two bevelled corners on both the diagram and fuse box (on the left side) , number 1 is indeed bottom left on both.
"They look correct to me when referring to the picture in the manual. Looking at the two bevelled corners on both the diagram and fuse box (on the left side) , number 1 is indeed bottom left on both."
It's hard to see on the picture but there are embossed numbers along each side which are wrong, the bottom left starts at number 16.
