I posted this in the Aygo forum but so far have had no replies so I thought I would try in the general forum.
I have a 2017 Aygo X-play VVT-1 and I am having trouble locating the interior fuse box. The owners manual and the online manual both say it is located on the drivers side and I have seen posts on here that say that's where it is.
I have just spent an hour trying to locate it, I have had my head right underneath but I cannot see any removable panel as described in the manual.
If someone could point me in the right direction it would be appreciated.
  • 4 years later...
Did you ever get an answer?
The interior fusebox is best seen from driver's side footwell looking up, if you find OBD port to side of it should be a white plastic box with removeable cover, that's interior fuse box.
Moved to the Aygo forum.
