HELP! yaris D4D, 2004 mysterious faults
Dennis Juel Angell
I'm hoping someone can help me with my 2004 Yaris Verso d4d! I am runnig out of ideas.
Problem 1:
The car is very hard to start. Starts at once with the use of a little start gas. But a push start always works.
Problem 2:
This is the worst one. If i push the throttle and pass 3000 rpm the car dies. After waiting a couple of minutes it will start again either with start gas or push start.
Things that are checked / replaced:
Front fuel filter
"feed" filter in the tank.
Pipe from refilling cap to tank.
Tank emptied and rinsed.
New glow plugs
Swapped High pressure diesel pump with a working engine.
Controlled diesel feed to pump.
swapped air filter box with mass airflow sensor from working engine.
I have run diagnostics on the car and the fault codes that are showing are:
P1229 - fuel pump
P0100 - Mass air flow sensor
If i remove the plug on the SCV on the dieselpump the engine does not die, but it is in limp mode. It is still hard to start. ( for some reason the engine light doesn't light up - I would think it is supposed to since the car is in limp mode and the ECU does not communicate with SCV - am I right? )
I don't know what to do next. I have an extra car that had an working engine before I began dismantling it, so access to parts is no problem.
Can anyone help me???
Dennis, Norway.
hmm, You've already tried a lot of things!
What about the fuel pressure regulator?
This one?
It's attached to the pump, so it followed with the pump I swapped from the working engine.
Yes. Swapped that as well.
