Ice Probs Help Needed!
Nizan
I have my screen and PS2 all installed now and its working fine apart from the sound, i only seem to have one level of volume, i
have all the audio running from the PS2 into the headunit so sound is comng from the front 4 Speakers.
its fine when its quiet but when its noisy like at a cruise or a mate is playing ps2 while im driving cant hear sod all.
In my headunit manual it says to run a TV/Video link through AUX mode i need a "M-Bus V-Link" (M-Bus/RCA interface cable KCM-122B) this means nothing to me :help:
Cheers
Niz
so you cant control the volume with the headunit is that what your saying??
or you turn it up but it has no effect??
i can control the volume with the head unit, so at 0 its off then 1-35 its all the same volume, if that makes sence.
yes that makes sense.
so.......
you have the red and white leads from the PS2 going to the headunits AUX in??
and i presume the yellow lead going to the screen for the screen and nothing else??
yeah red and white going into headunit.
Yellow is going from ps2 to TV, but not sure if it does anything else, do you think this might have the volume control in it???
hi there, you need this:
Apline - kcm122B
I just bought one for my system, and I rate this company, I have spend a fair bit with them, and scored 148.1dB with their help :)
Problem may be that you have pluged your red and white rcas into an output on the head unit, not an input? You wont have an input until you have bought the lead.
Im in the same situation as you, but my lead should turn up today :D
edit: Having read the post again, :wacko: my first paragraph applies
HTH
ahhhh cool tyvm, i think i see what i have done now :D
it looks like the ends of the leads on the link you gave me are DIN (is this right?) i only have one slot for thease currently being used by CD changer, can i buy a junction type think for this too???
soryy for all the questions but i reall have no clue about this stuff.
right, as I dont know which headunit you have, take a look at this link :)
http://www.caraudiodirect.co.uk/help/ipodfriendly.html
It talks about adaptors so you can use an Ipod, but essentially you are doing the same thing, just with a tv instead. If your manual says you need the 122b, it doesnt look as though you can use the changer :(
My Headunit is a Alpine CDM-9835RM
it says in my manual i wont be able to use the CD changer When the tv is on if i buy the KCM-122B adaptor , local audio shop said they will have some in on Friday.
Cheers
Niz
