Fault error code P2112
Mashd
Hi everyone,
I got toyota auris 1.3 petrol 2009. My car has generated faulty error code P2112 !  Can anyone please tell me from his/her experience how much is it going to cost me , do i need to replace full throttle body or is there any other solution pls ?
how did you sort it out If you had similar problem..
Look forward to hearing from you soon
  • 4 weeks later...
hi ,
i changed my car's throttle body i bought used from eBay , now its working fine....but very poor mpg , i am getting 28 mpg in city and 38 on motorway
I'd clean and put back the original one.
It's possible that your ECU is used to old throttle body, a quick reset might fix this (disconnect Battery for 10 minutes, reconnect, start car and let it idle for 10 minutes).
