Starting problem with aruis
Robmac26
Hi can anyone help with a problem u have with the aruis
When i turn the key to start i wait til tge glow plug light goes out but when i try to start the car nothing, no clicking of the starter motor, the lights go out on the speedo and rev counter, just nothing happens, i dont know if its the key or starter motor.
Hope some can help
How is your Battery?  Can you maybe measure it with multimeter, to see the voltage?
Have you tried the spare key to eliminate it's the key?
36 minutes ago, furtula said:
How is your battery?  Can you maybe measure it with multimeter, to see the voltage?
Hi furtla
I only have one key and iv put a buster on the Battery as well, l can out headlights on so i don't think it's the battery
Thank s
So the glow plugs work, but cranking not? I guess the key is technically fine.  You wrote the lights go out on rev counter and speedo, do you mean they turn on?
You tried tapping on the starter motor with hammer or something similar?
Il go try it now, let you know
Thanks furtlua
All sorted engine turned over but Battery low , I did give the starter motor a smack
And thank you every one up and running now
