How many tracks
French Auris
Hi all, new here so sorry if this has been mentioned before.
I have a Auris 2018 Design Hybrid.
I stuffed loads of tracks onto a usb stick, more than 1200 and it showed 600 plus tracks, then I decided to convert them all into MP3, now with 1228 tracks my USB stick shows only 499 tracks, is this the max capacity ?
I did read somewhere that someone has over 700 showing.
Anyone got any ideas, ideally I would like all music on one USB stick
The USB stick I have in use atm is a Kingston 2.0 32 GB
1 hour ago, furtula said:
Have you tried separating into folders?
No, I have not as yet, does this work?
2 hours ago, French Auris said:
I don't have your model, but it should work, having folders even works on my 2007 Auris, and i switch with 2 buttons folders up or down.
Yeah sorry, auris design hybrid 2018 model.
Sent from my LG-H818 using Tapatalk
Thanks for the heads up on this, I added all my tracks to 4 folders, tried it and it does`nt show the folders but it does show all the tracks, so thanks for the help 🙂
Now the Mrs is happy.
