Rav4 Hybrid engine coolant temperature
_dct_
Hello wiser ones,
Does anyone know what the normal operating temp for a Hybrid should be? I have the Hybrid Assistant app connected to a OBD2 bluetooth adapter and the coolant temp reading never goes past 82-83 °C even after a long motorway journey with very little EV drive. Is this normal?
You'd need to check the spec with your dealer or by paid access to Toyota's technical manual. Many Toyotas have thermostats around 82C so your car is probably fine.
