Head unit B9012 Wiring Diagram --> Looking for Camera wires
Rwin
I own a 2010 Avensis. It came with a B9012 and rear view camera. I recently replaced the unit with aftermarket Android 8 (PX5 Chipset) head unit. Everything worked instantly but... i like to use the camera already in the car. Problem: i can't find the wires. I guess they should be in the 20 pin connector at position 1, 2, 11 and 12:
Unfortunately, i can't get it to work. When i put the car in reverse the new head unit switches to video input but no video signal 😞
Questions:
Does someone have the pinout for the 20 pin connector used with the B9012?
The Toyota camera, is this a 6V or 12V camera?
Something i'm missing?
Thought i had the solution but:
https://www.qualitymobilevideo.com/ax-toycam2.html (24PIN)
https://incartec.co.uk/category-listing/Reverse-camera-retention-adapters (16PIN)
Nothing in the middle 😞
And found http://carsounds.nl/producten/camera-interface-toyota/acv-camera-adapter-toyota-diverse-modellen-2/
But with this one i will loose the other steering wheel controls (and ground)
  • 2 years later...
Hi Erwin,
Did you manage to solve this issue? I'm facing the same problem. The unit switches to video but no signal.
Thanks in advance
Hans
