Does anyone have any information? . Corolla Corolla Comressor 1.8, 165 kw, Year 2005 engine 2ZZ-GE.
In my car, fuel nozzles with spare part number 23250-YW201.
Is the nozzle original?
Thanks to Jussi
You can try entering VIN number for your car in http://japan-parts.eu/ then search for the part and check the part number.
I did a quick search for 23250-YW201, but there was nothing.
I did not find the selfish VIN number information. Has any one of the Compressor owners taken the fuel out of the nozzles and took the VIN number into memory?
picture of Corolla Compressor nozzle.
The compressors are unique as they were built and left the factory as standard 190 Tsport Corollas they were then shipped to Toyota Motorsport ( then Toyota's sports division, now called Gazzo ) where they were converted to Corolla Compressors using a crate full of conversion parts.
If you look the car up using Toyotas parts catalogue all the parts will be standard 190 Tsport, there is a Special .PDF document containing a repair manual, part list etc which covers all the items that differ to a Standard Tsport.
Your part number for an Injector is correct, it is one of the many Compressor specific parts
Big thank you for your knowledge,
You said there was a special .PDF document containing a repair manual, a list of parts, etc. covering all items that differ from the Standard Tsport system.
Do you want to put a link or address on where to get the Corolla Compressor repair manual?
