Wiper Gaiters
Soeley
Not sure if this has been covered before or not?
But just a quick guide to replacing the wiper spindle gaiters in the scuttle panel. I noticed last weekend mine had perished, so I ordered two new ones from my local dealer, about £11 each.
Picture 1: First of all remove the covers off the wiper arms to reveal the nuts, then remove the nuts (14mm socket). Tip, put a mark on the spindle to aid in re-positioning the arms later.
Picture 2: Split gaiter
Picture 3: Remove the plastic rivets at each end of the scuttle panel
Picture 4: Plastic scuttle panel removed
Picture 5 & 6: One split, the other just showing signs of splitting
Replace the gaiters with the new ones, I sprayed a fair bit of white lithium grease inside the new gaiter to lubricate against the spindle shaft before fitting. Put it all back together in reverse order.
Why bother? I'm sure I read  somewhere on here previously about someone having trouble with the wiper wheel boxes due to water ingress through the split gaiters.
Found mine in a similar state a couple of years ago when I removed the panel to fit new spark plugs. Reminds me I need to look at them again and add some more grease if needed before the new ones split.
Craig.
