Mk2 Yaris power window failure.
rufnek2kx
Hi all,
I noticed last week that the N/S power window stopped operating on either switches (thankfully in closed position). O/S window works fine and there is no noticeable noise when pressing either switch for the N/S window. I suspect it's the motor but are there any other checks i should be doing before taking the door panel off?
Secondly, can I replace just the motor itself or does the whole regulator need replacing? Local dealer said the motor isn't separable but they've been known to bs me in the past.
Have you depressed the window isolation button on the drivers door (button with the shape of a window crossed out)
  • Haha 1
Ohh ffs, can't believe I overlooked that one. That's exactly what it was. Cheers.😂😂
