Hi, hope someone can help.  Info from handbook etc
Have a Corolla Verso T Spirit D4  Chassis  EX28E200029450  Reg  T9 GBC    Eng  1CD0319733      D4D      2003
Problem, every time I go on line for a part , even something like rear brake discs, or pads or front discs etc or most things,it looks like  vehicle list covers Verso, but when I fill in the details to check compatibility it almost always comes back as - parts will not fit this model"    Same when I phone places. Cannot believe this model is that different to others on basic parts ?    I often see on chart some model numbers like ZZ or CDE etc    how can I get a more accurate number or can anyone advise if some other Corolla is almost always same in regard these brake & suspension parts ?  I need rear brake discs and pads and dozens advertised on E Bay at good prices but not one ad confirms they will fit my model;
As it is a 2003 model it is different.
The original Toyota Corolla Verso was only exported to Europe for a couple of years or so, and was the Toyota Spacio renamed.
In 2004, Toyota introduced a new, larger Toyota Corolla Verso (later renamed just Verso) for the European Market that was built in Turkey.
Thanks for info and  explains why various charts do not seem to recognise it
Does it mean that even for Brake discs I will have to go to Toyota and order genuine ?
The genuine parts numbers are:
42431-12250 Brake disc rear
04466-52030 or 04466-YZZD5 ( First is original # second is Optifit Toyotas cheaper option ) Rear brake pad set
Should be able to cross refer
