change of engine
David moxon
Anyone know if an early t25  1,8vvt petrol engine will fit into a late t22 ?
It should,
As I recall, the engine on both models is the 1zz-fe
Sent from my Nexus 5 using Tapatalk
Without actually looking into it fully I wouldn't like to give a definitive answer just incase but I can see no obvious reason why it should cause any major issues you're basically replacing like with like
Sent from my SM-N920T using Tapatalk
