Engine not starting after SCV replacement.
pjackson
I've just replaced the SCV on my 2007 Corolla Verso 2.2 D4D. It's an identical original SCV,  not the newer revised one. The engine just turns over without starting. I've checked the operation of the new SCV in case it was faulty, but it's fine. Does the fuel need to be primed in anyway, and if so, how? Thanks in advance.
