Torque specs
Luke4efc
Hi all,
I have a 2010 Auris 1.33 VVTi (I believe the engine is a 1NR-FE) and my front driveshaft seal has a leak so I plan on replacing it soonish when I do a full service. I can't seem to find a workshop manual for these anywhere so could do with someone to just confirm the torque specs for me and if I need to replace the nuts aswell. If anyone knows of any software manuals available then that would also be of some help, cheers.
Also I know the engine oil sump plug requires a new seal every time, is that also the case for the gearbox fill and drain?
Track rod end - 40Nm (possibly new nut?)
Front hub - 216Nm (new nut required)
Oil Filter - 40Nm (that seems quite high for an oil filter to me)
Sump drain - 30Nm
