Lowering A Yts
earpl
where do you get springs from to lower the yts? if seen them for the yaris but i guess them on a yts might not make much difference? i want to lower by like 30/40mm. cheers.
Cobra have springs for yts and at least -25mm springs are only for tsport but it's not enough for you.
G&M springs lowers front -50mm and rear -40mm.
Intrax (-40mm) spring does a goob job too: Intrax -40mm
TTE spring -30mm lowers tsport... i guess -20mm or something. Not too much anyway.
