MMT Stuck in N problem garrage wants £2200
Auris_MMT
I have a 2009 plate auris with about 48,000 on the clock. It went to flashing N in a traffic queue and would not move.  Had to get towed. The toytat repair place in Haynes say new clutch,  new flyweel and new acuators, £2200. This is possibly not economic. What is the suggested course of action?
It has previously appeared to drop out of gear on other occasions, somtimes with the flashing N, other times not.
If it was dropping put of gear before it won’t be your clutch disc or flywheel.
most likely to be your clutch actuator which is a known and common issue on these cars.
As previous post says its defo ur clutch actuator.  Dealers are inclined to do all clutch flywheel etc
