My mmt gearbox gone crazy one day, changing 1st gear to 5th,,,,so I went to toyota service and checking the car on the computer they found nothing! No codes no errors,,, saying they need lots of hours to inspect all wiring... I took my corolla back home stragling and then discovered a burn fuse! On the fuse box under the steering. A 10A GAUGE fuse which is a general fuse(dash lights, reverce lights etc). When I changed the problem was fixed. It burned because of the parking sensors when I engaged reverse on the mmt and occurs that's has an effect on the gearbox also. So be aware!
