AutoExpress Headlight Bulb test 2018
Heidfirst
N.B. They tested H7s which I am not sure that any current UK Toyotas use (but older e.g. Avensis T25 did)? Quite possibly a fair reflection across to other fittings though as the usual suspects (Philips, Osram & Ring) are all up there.
https://www.autoexpress.co.uk/accessories-tyres/76760/best-car-headlight-bulbs-to-buy-2018
P.S. wasn't sure which forum to put this in so Frosty please feel free to move ☺️
General discussions is fine - pinned.
I just had delivered Ring +130 H4 bulbs for my Carina II. I will do a 'blank white wall' comparison (and check adjustment) .... Mind you, at this time [here in the N East] 20minutes driving on the salty roads reduces brightness to 'fork andles'.
Will report back
2sav
..... bulbs fitted! Much brighter and sharp.
I haven't been out on an unlit stretch of country road yet but I'm sure they will be some improvement.
Royal chew-on fitting the n/s, as it is tight behind the Battery.
2sav
