Blower Fan Speed only works on 1 and 4
roastedchicken
Hi All
Sorry if this has been raised before, but I've got a 2008 auris and the blower works on 1 and 4 only.
I've dismantled everything in the dash, the contacts seem find within the rotation switch and I've tested from some rear test points, but the connector pin I can't easily correlate if it's actually working or not because I can't work out the pin-out.
Has anybody had this issue? Just wondering if there's a way I can either fix it, or isolate it easily to the blower or control switch
Just to add, I've tested the blower resistor, appears to be fine? .8, 1.6 and 3.x ohms, seems reasonable
Blower motor working only on certain speed, or just one is symptom of a faulty resistor.
I'd check the pins first for some corrosion or bad contacts first.
Here are the schematics for manual AC
http://www.autocats.ws/manual/toyota/auris_corolla_zze-zr-nde-ade/rm04f0e/ewd/index.html
