Intercooler hose seals
Archie0979
My intercooler hose is leaking as the o ring seals are gone. I can find a new hose with no problem but could someone point me in the right direction to find new seals please as I can't find them anywhere?
Thanks for the diagram links. The mechanic I use contacted Toyota today as the parts distributors he uses told him it is a Toyota specific part. After contacting Toyota they told him that they don't supply the O-ring on its own and that I would have to buy the whole pipe from the turbo to the intercooler complete with fittings for a cost of £80. It is only the O-ring in the lower hose that connects to the intercooler that is causing problems so the mechanic has said he will take the old lower pipe off, give it a good clean then put it back on and run sealant round the outside of it.
